lewtot184
Don't alter the accelerator pump check ball/needle. It helps in cicut drain back. I use a .028 squirter, orange pump, rod on top hole and 7/16 float setting. No hesitation.
G haven’t checked it hooked up to vacuum can just with vacuum gauge to manifold that’s where I’m getting 14 in park 10 in driveWhat is the idle vacuum with the VA unit connected to manifold vacuum? The man vac port is the lower port on the front of the carb.
