I'll save my comments on the logic of using these heads or keeping "details to yourself... because this is a magazine build..." for another time. So I want to make sure I understand where you are...
You're doing a combo that's been done a thousand times over, right? You know you need hollow pushrods, and some sort of non-shaft rockers. So you're good there. You're up to "what pushrods?"
Anybody that's done any performance building more than a couple times will tell you: you get it all together, measure for the pushrods, then either order a shelf part number if one matches what you need for length, size, end type, and end radii... Or order custom ones (which is what I do 80% of the time). It was suggested earlier - order some checking pushrods, and then measure for what you need. Manton or Smith Bros will make exactly what you need, or Comp may have a set but you have to do the diligence. There is no "use this pushrod" when nobody knows what the block is, or the gasket, or the rocker, and this is all "Code 5" so you won't tell.
