troublemaker
Hey folks, thought I would pass this on. I am running a FAST efi with a FITECH 6 barrel throttle body, MSD 6al, MSD distributor and coil. The MSD tach wire is connected to the efi module. The dash tictoc tach. needs a signal. The tach. has been reworked for an MSD signal. My question was where to get the signal? Various articles are posted throughout the internet, piggyback off the MSD feed or come off the negative side of coil, MSD Instructions tell you to never connect to the negative side. I called MSD, they told me what I figured, stay clear of the negative side, splice the tach wire as close as you can to the box, the MSD box will adequately feed the efi system and the tac.. Plan on doing it this weekend and will let you know how it works. Just an FYI for anyone messing around with EFI. This is on a 70 RR 440, 4 speed.
