Vincent Holt
If I had a multi-meter what type of reading should I be looking for?The light is as bright on the coil as it is on the +/- battery terminals.
If it was a poor ground connection... wouldn't the ground wire be hot as well?Also, please let us know or show a photo of where exactly the coil ground cable is connected on the other end. If it's to the head, sometimes this can be a poor ground and cause coil overheating.
With my blaster 2 I use a 1-ohm ballast resistor, but I have a Firecore electronic distributor.
I Reused the factory coated coil wire as + lead after combining the brown/ Blue wiresIf I zoom in on your coil photo, to me it looks like you have your + and - sides hooked up backwards. It looks like the large black ground wire is hooked up to coil +
Also, don't leave the key on for too long without the engine running.
Ok.. I will try that tomorrow afternoon for sure. I'm trying not to burn dinner right now.I would of wired things differently in regards to eliminating the ballast resistor and full 12 V
Quick test
Run a jumper wire from positive side ignition coil to positive side battery and see if it starts quick when cranking over - Leave other wires hooked up to ignition coil
Let us know either way - Don’t forget to take jumper wire off when done
Bob, I can agree with that 100% BUTIMO......just replace the coil as it's the easiest to change (by substantiation)....rather than fussing with all these tests suggested......you'll know conclusively wjich component is defective......
BOB RENTON .
To test, use any coil.....Mopar ORIGIONAL factory coil is fine for a test The spark voltage will be slightly lower.....the distributor module just switches the coil ON/OFF (when the spark occurs) and will test the supposition....if it starts you'll know how to proceed........the Mopar coil needs a ballast resistor but for a short term test it will be ok........IMO....Bob, I can agree with that 100% BUT
1. Mine was brand new right out of the box!
2. They are $80-90 without shipping.
3. I was hoping to get an answer on trouble shooting the problem for future issues and also for someone else who has this problem can search and find this thread.
Key in run positionIf I had a multi-meter what type of reading should I be looking for?
Bee1971,Yes
But that RTR Distributor requires 100%
12-14 Volts to fire off that module
Hence the quick test or tests
And every mechanic should own a Volt Meter
Correct Bob or is that to much of a fuss
not necessarily. If the + and - wires are connected in reverse, then the motor will start, but the spark from the coil will be weaker and make it overheat.If it starts the coil is working correct
LOL
wait, I thought you said the red wire is positive and the other black wire is ground? In reality is the red wire ground and the other 3 wires wrapped in black and connected to + terminal?I Reused the factory coated coil wire as + lead after combining the brown/ Blue wires
Ihavewait, I thought you said the red wire is positive and the other black wire is ground? In reality is the red wire ground and the other 3 wires wrapped in black
The negative side of the coil is only the orange wire from the MSD distributor.wait, I thought you said the red wire is positive and the other black wire is ground? In reality is the red wire ground and the other 3 wires wrapped in black and connected to + terminal?
It doesn't figure. I just had the problem with no spark on my runner. Did not do anything but pull heads on the car to paint the shock towers over again and had a cracked head. Put it all back together and no fire. Even bought a new coil. Did not do anything to the wiring or distributor. I was stumped. Low voltage at the coil. Ballast resistor was getting hot. So took a few days and got it running. Tie raped my wires back at the bulkhead connector and to make it neat. No fire. This drove me crazy. So took a day off from it but still thinking what I did. It was running now it don't. As you all know I had a top rad hose blow off and fluid went everywhere. Had cleaned the bulkhead connector with contact cleaner. So revisited the connector and saw that it still looked dirty. Cleaned everything again and notice upon plugging the connector back on to the main plug the brown wire moves out. Pulled it back apart and the brown wire spade was loose in the connector. Had to bend the tab on it and push back into the block. Put the two plugs back together and used a small screwdriver with a flat blade and move the spades in further. Got fire. So just saying the simplest thing can get us. Sometimes we just have to walk away and go back at it later. Start afresh. Wish you luck with it and hope you get it figured out.![]()
