SwedCharger67
That's an interesting point.My advice here would be to choose a cam profile compatible with aftermarket EFI if you are contemplating going with that over a carb. Most aftermarket EFI will require a certain vacuum level at idle for best performance with the systems operating parameters. Even the tuneable systems will have trouble with a cam that doesn't produce at least 12 inches at idle....
There are different ways to control how much fuel is injected. I can well imagine that some systems measuring the intake manifold pressure will struggle a bit with a big cam and low vacuum, fooling the system to believe that the throttle seems to be open quite a bit.
Many high performance motorcycles use just the TPS and RPM as a reference to how much to inject (and adjust for air pressure, system voltage etc.). It works well, I have it myself in my Ducati 996SPS with dual injectors per cylinder.
I have to study those details in my own system, since I'm going to use a low vacuum cam, thanks for pointing it out.
