- 5:01 PM
- Oct 16, 2014
- Salisbury, Vermont
2002 Audi A4 electric speedo to 1973 727. Solutions??
" What chu talkin bout Willis?"Hall effect drive at the transmission?
Do I need to know how many pulses the speedo is?Most electric speed senders are 3 wires, red, black and white as the signal. You can pick one up on eBay for 30 bucks. Worth a shot.
As an example....here is an electric converter for a speedo drive" What chu talkin bout Willis?"
To me it looks like you need the correct pinion for the speedometer drive already inserted in the transmission. Then the new unit screws onto where the cable would normally go - and from there the cables carry the signal to the speedometer on the dash. Conversion or compatibility of that signal is the next task to figure out. Have you any factory manuals or information about the Audi speedo output signal?Okay. This is the speedo gear and cable from the transmission i'm using. Where does that thing plug into this set up?
