Dad's69RR
Ok installed new backup/NSS switch and no change. Traced and checked all wires and found that I had power to the left turn signal at the front and at the switch. As I stated it would come on as soon as I connected the battery so started tracing the circuit and verifying interior bulk head to exterior. I removed the fusible link from the starter relay and the light went out! This directed me to the amp meter on the dash and found the stud the red wire is connected to was loose, I tried to tighten and noticed the gauge is broken and not making a good connection. (Stud twists with the nut)
My question is if I take the same red and black wire and extend it to a Summit Amp meter will this correct the issues I am having? Would this be causing both the no start and power to the left turn signal? Just wondering since the amp meter was broken on the inside if it would make things wacky?
One last question, when hooking up the Summit amp meter will I have to add any wires? Sorry for so many questions.
