tag
I'm trying to get the electronic choke hooked up on my Edelbrock. The car is my 1967 Satellite "Running Project", sporting a 440. I'm wondering which switched 12 volt source is commonly used for this. My harness is original (as is most of the car...except the 440) with the few mods I've made to it (MSD Blaster 2 Coil, MSD ECU/Pro-billet combo). I initially just rigged it to the positive terminal of my coil, albeit this isn't the idea spot since I know the element in the choke unit can draw quite a bit of juice. I am running a 12 volt coil with no ballast.
To my surprise yesterday when I fired the car up after rigging this and then shut it off to adjust the coke so it'd actually close cold, I discovered when trying to re-start that my starter had given up the ghost. So I popped it out, picked up another starter, slapped it in...and the story repeats itself. This is two starters, it was from Napa so I might chock it up to bunk parts (wouldn't be the first time). In either case I'm going to change the harness so it's not running off the positive coil terminal just 'cause well, the instructions say not to anyway and I don't need that element drawing from my coil's lead. But I was wondering if any of ya'll think this could some how be related to the zapping starters, I haven't been able to reason about any rational possibility that my choke is frying the starter so I'm assuming it's just a coincidence.
Here's a photo of the rolling project, just for fun:
