Electronic ignition and tune up Part numbers Please
2:54 AM
Memphis TN
Good Morning fellow Mopar Enthusiasts,
Working with a
1966 Plymouth Satellite (original 318) now 440 1973 engine 727 transmission
I want to do a complete ignition overhaul and tune up.
Don’t want to recreate the wheel, can y’all help me out with some part #’s where to purchase
1. Pertronix III conversation
2. flame Thrower III
3. Cap
4. Rotor
5. Plug wires
6. Plugs
7. Any other hardware for routing Plug wires
8. Additional Advice
Thank you,
Memphis Rich
Best bang for the buck is the GM HEI 4 pin module conversion. Pics on the web of the module mounted on the side or under the dist. You could use your existing coil & bal resistor with it but better spark performance using an E core coil such as MSD #8207.
You could even use your original points dist to trigger the module, but better off buying a new electronic dist from Summit & using the mag p/up to trigger the module.
