Emergency Flasher
dvader
1:12 PM
Mackay, Id
I am trying to trace down a short in my Emergency Flasher circuit. I have found the turn signal flasher but I can't seem to locate the Emergency Flasher under the dash. This is in a 69 Road Runner. Thanks for your help.
Check just above the ignition switch that is where mine is. Tight spot but reachable.
If you found your turn signal flasher on the side of the ash tray assembly, check the other side for the hazard flasher. That's where they are on '68s. There's a little receptacle on each side that the flashers plug into. Flashers apparently used to be rectangular and fit in the receptacle. New style round flashers don't fit.
I had a really hard time finding mine too but used my phone to take pictures under the dash. It made it much easier...
Thanks guys. I found it on right side below the ignition switch just like you said. Not easy to get to and not easy to hunt down. Thanks again.
