69 Sleeper Bee
- 11:53 AM
- Feb 18, 2021
- Tallahassee Florida
Have you by chance checked your K member mounting bolts to make sure they are tight ?
The reason I ask is I just can’t understand how a motor can move that far forward unless you hit something hard which I know you didn’t.No but that's a pretty good idea.
So far every bolt on the car has been tight so chances are low, though.
I've never used the ones you link to, I went straight for the kill w/ a solid on the driver side and haven't looked back.Well that sucks since i bought them because they state in the description:
"You absolutely WILL NOT break these mounts ever! In fact, they are covered by a LIFETIME WARRANTY for as long as you own the car!"
My car is 100% stock so it should make 375 sae gross hp and since it's got 90k miles on it it's probably less. (But the engine is healthy / no slouch)
@beanhead What are you using and think about these?
[/URL]
Yes it will vibrate the chassis more; how much depends on the temperament of the engine. I found that solids on both sides were just too harsh for me (racy motor but lots of street driving) so I put the factory-style biscuit back on the passenger side. That tames the extra vibration for the most part but keeps it from lifting under power...no complaints.Unless mine break soon ruining another radiator i won't.
Man those are even cheaper but i want to keep the car stock.
Does the car vibrate a lot with these? To the point that it's unpleasant for a daily driver?
Load it against the brake and have someone watch to see how much it moves. Disclaimer: if you don't know how to do it find someone to help that does. If you don't know what you're doing you can hurt somebody or run your car through the back of your garage.
How many years have you been involved with working on cars compared to Michael and what is your background? Like I maintain not everyone has worked on machinery, trucks and other vehicles sine they were old enough to notice. I was hauling grain from the combine to the granary when I was 13 years old. Started pulling implements in the field when I was 11. Had a city cousin who didn’t no anything about farming, but was self assured about doing things. After a few miscues he learned.Oh bah humbug! I can do (and have done, many times) the mounts on my '68 (w/ power steering and headers) in less than an hour, with nothing more than a floor jack and regular hand tools. I keep the car on the tires and the engine only needs to be moved a small amount to take pressure off the through-bolts.
10 hours?? Ho-lee crap dude.......
In case you didn't notice, we did have some helpful and serious conversation on the matter..and the OP seems to have no problem (and a maybe an actual sense of humor?) about my postings...How many years have you been involved with working on cars compared to Michael and what is your background? Like I maintain not everyone has worked on machinery, trucks and other vehicles sine they were old enough to notice. I was hauling grain from the combine to the granary when I was 13 years old. Started pulling implements in the field when I was 11. Had a city cousin who didn’t no anything about farming, but was self assured about doing things. After a few miscues he learned.
I think the key word in your post could be many times of doing it.
Example. I try to get by with the computer/internet usage and I screw up a lot and I am at the bottom of the knowledge pool.
I am having a real problem trying to figure out how to work and manage my private messages. I think my inbox is close to being full, and with the new format I have a real problem dealing with it.
Main point have tolerance and help people if possible.
This comment is for everyone and not personal.
They don't vibrate at all. I do run standard rubber trans mounts however. From all the reading on the subject, you aren't suppose to run all 3 solid mounts together.Unless mine break soon ruining another radiator i won't.
That's good info to add...I've always used a rubber transmission mount too. They say that using a poly mount with solid engine mounts can crack the aluminum case. I don't know how much of that is truth vs. internet myth but I don't wanna find out the hard way!They don't vibrate at all. I do run standard rubber trans mounts however. From all the reading on the subject, you aren't suppose to run all 3 solid mounts together.
That's good info to add...I've always used a rubber transmission mount too. They say that using a poly mount with solid engine mounts can crack the aluminum case. I don't know how much of that is truth vs. internet myth but I don't wanna find out the hard way!![]()
