John K Nelson
Problem started this spring. Mostly low rpm driving or at idle. Once it shut off with 13+ VDC at 1100 rpm fast idle at start-up. Once in water box at race track. Don't recall if it was at 4000 rpm tire cleaning or when I lifted to idle up to the tree.
64 Plymouth; built in 2010; new wiring harnesses; MSD6AL; battery in trunk; Powermaster 160 amp alternator; smallest pulley allowed by PM for highest charging rate at low rpm.
I have replaced: 1. the ignition coil and moved it away from the engine. 2. Cap and rotor. 3. magnetic pick up in the P369071 distributor. 4. Battery.
New ignition switch on order.
Charging system issue?
Bad ground somewhere?
