kiltedrunner
Engine vibration at 2900-3000rpm - HELP
Hi Guys,
First off, I should say that this was a major project for me. Everything changed on my car including suspension, engine, transmission, fuel system, cooling, and much of the wiring... with that said...
I purchased a used motor a few years back and it had lots of good parts on it. I never pulled the heads off, but did install a new cam, lifters and pushrods. I finally got the engine into my car last January. Overall, I am quite happy with the entire project, but as always there are some gremlins I'm working through. Mostly I have it all figured out, but unfortunately there's something causing a fairly major vibration between 2900-3000rpm. It smooths out below and above that rpm range. The engine consists of the following specs:
400 block mopar with a 440 crank ground to make 451ci
Electric waterpump & electric fans - only external items are alternator and power steering
While the engine ran great overall, I noticed a few symptoms with the engine:
I believe it could be one of the hydraulic lifters bleeding down that's causing this issue... but I'm not sure.
What do you guys think?
Hi Guys,
Hydraulic roller cam and lifters - comp cams
B1BS aluminum heads
11:1 compression
EFI (throttle body) - EZ EFI 2.0
High torque starter - summit?
727 automatic trans with 3000 stall converter - ProTorque (New York)
I should also point out that the original engine had the oil passage ways blocked off for solid lifter use. I pulled all of that out - so I don't think I'm starving the number 1 cylinder - but it is the last cylinder to get oil on the bank.
B1BS aluminum heads
11:1 compression
- Starter slows down when turning over number 1 cylinder. The starter has a really hard time starting the engine if it has to start turning from cylinder 1, while it spins quickly on all other cylinders.
- Engine usually stops spinning at number 1 cylinder when I shut the engine off.
- I have a very high cylinder pressure - 220 on cylinder one - but lower on all others.
- Vibration when revving engine to 2900-3000rpm while in neutral. I can't separate the converter from the engine because I need it for the starter. Converter company claims that it's balanced dynamically before shipped. It's not the drive shaft, because I have found this issue still exists while the trans is in neutral.
- Lifters on cylinder one seem to bleed down - can't remember if it's intake or exhaust though.
