fatecaptured
So incase this helps anyone, here is where I got the tires and belts: https://www.dynamtechgroup.com/car-stereo-belts.php
The fast forward tire isn't listed on the page but he was able to get it for me.
That part number is: P/N 06-0102
The tires are $6.50 a piece. The belts went up in price from what they have listed. UPDATE 1/26/20
THIS ISN'T THE CORRECT TIRE FOR THIS RADIO. BUT COULD BE MADE TO WORK WITH SOME OUT OF THE BOX THINKING.
The capacitors came from Digi-key. I got all the caps to do the head unit and the tape player.
I've been on Mr. Carlson's patreon page learning about radio restoration and repair. Wished I would've done that prior to buying the caps. I got some tantalum caps because they didn't have the right sized electrolytic capacitors. They are not suited for radios as they can cause static. I should've gotten polystyrene capacitors instead.
Another tip: if you plan on changing out the caps, they are polarized. If you put them in backwards they will blow up. A schematic is definitely needed. Also you want the foil end to shield the cap as to not cause any noise in the circuit. The polystyrene caps may or may not be polarized but they do have a foil end. In most cases you will need a outside foil tester for the polystyrene caps if they aren't marked or specified in there data sheet
Here is the list from digikey:
