The blue & brown wires are the ones that are attached to the ballast resistor.
I am not conversant with the FAST system, but I would imagine that it is like the Holley Sniper, in that the ballast resistor is not required....hence.....just join all those wires together. That will give you the 'Hot' in both Ignition ON, and Cranking with the key.
A picture of two of the finished connection would be handy - once you remove the ballast resistor.
Don't worry about under the dash for now.
