- 12:54 PM
- Apr 23, 2018
- Nanaimo B.C. Canada
Yes, on both counts.
Thank you. Wasn't a 8 3/4 a bit much for the small 318? Or maybe the axle changed somewhere during it's lifetime..Yes, on both counts.
That’s a polyThanks for all your answers guys!
This Coronet arrived in the Netherlands a couple of days ago. And is not mine yet. If all goes well the car goes on a lift tonight. That way we'll be able to see more of the car. And find out what engine and tranny are in it.
Is a Poly more or less desireable than the LA version?That’s a poly
One downside to the Polyspherical - much like its' big brother the Hemispherical - is it's relatively Heavy! A Poly is close to as much as a regular 440...like 50 or 70 pounds less, I believe?Is a Poly more or less desireable than the LA version?
Wow..One downside to the Polyspherical - much like its' big brother the Hemispherical - is it's relatively Heavy! A Poly is close to as much as a regular 440...like 50 or 70 pounds less, I believe?
Shortblock is same weight just heads and intake are heavier, but much wider than the LA. Much less hipo parts for the poly.One downside to the Polyspherical - much like its' big brother the Hemispherical - is it's relatively Heavy! A Poly is close to as much as a regular 440...like 50 or 70 pounds less, I believe?
Wider overall because of the taller heads. The block is the same width as the LA block.Shortblock is same weight just heads and intake are heavier, but much wider than the LA. Much less hipo parts for the poly.
There's also one made for the slant 6 too. In all versions, there were both long tail slip yoke and short tail bolt-on flange versions, along with both linkage and cable shift depending on year. Truck/van/motorhome versions have a timing hole cut into the bell housings for easier ignition timing. The A100 version has a unique mount where the transmission hangs from a mount rather than sitting on one.Big blocks have a different bolt pattern, so there's a BB 727 and SB 727.
Same as mine, only option other than Hemi-4 speedMy info lists a G1 as being tinted glass all windows. Doesn't look like it from your photos though...
