I checked out the bolt hole that was full of oil and everything looks fine around it. They are so far out on the edge of the block flange that there isn't any oil or water passages around there. It looked like oil so I suspect there was a valve cover leak long ago that must have been funneled into it by the dipstick bracket.
I have Carl's book on 727 transmissions and the 67 Plymouth shop manual so I'm in good shape with those. It's just picking out the good parts from the bad parts - typically that takes a practiced eye or feel.
Just wondering - can the inside of the transmission (clutch packs, bands, planetary gears, pump) and tail housing/governor all be removed prior to removing the valve body and accumulator springs/pistons, etc? If I dropped the tail of the transmission down on the hoist it would be pretty easy removing the insides and tail pieces after which it would be a lot lighter to lift the gutted transmission off of the hoist and then pull the pan and valve body on a work bench.
