Whatever! Is not posible to make what you said on these ammeters without destroy or bypass the amm.
Here is another example of a Mopar amm ( 75/78 B body ) designed for a shunted system. A basic one without a voltage warning system.
The coil creates or amplifies the magnetic field to move the needle with just afew volts/miliamperes when a shunt was installed on these cars.
Since the gap between studs is the same we could try to install one of this ammeters into an earlier full load system and become our cars into a shunted system. I have thought on that back in 2008 or so for my car ( that's when I got a dirty cheap NOS M body amm, the one pictured on the earlier reply... that's in fact my own hand ) just needing to get a matching indexing ammeter ( needle pointing up or down ) and aprox same sweep and ratious, replacing face, trimming here and there to match deepness into cluster... BUT we don't know how much is the shunt resistor value to get the right reading on amm. So that's when my project stalled.
Mostly sure the best bid to proceed with this conversion successfully would be try to get the shunt from the same donor car the ammeter came out. In my case, an M body harness with the shunt. But I decided to left at a side the project for more important things
