gibber
Hi Jim,
I would bet your oil press gauge isn't accurate, if both the fuel and temp gauges don't work. All 3 thermal gauges use 5V, and that points type limiter inside the fuel gauge is probably acting up. , . Once the voltage input goers up (due to the bad internal limiter), the insulated nichrome wire starts to cook and first the calibration goes away, and if over voltage lasts long enough, the wire will burn in half and the gauge will cease to function. That needs to go away if you want the gauges to work correctly from here on out....see above on the IVR-3 RTE limiter conversion...
Thanks,
Mark
Thanks,
Mark
