bandit
I am replacing the electric fuel pump with original mechanical pump setup(that buzzing noise is getting too annoying). On the existing setup, the steel fuel line coming from the tank stops at about the firewall and then it is a mix of copper line and rubber hose to the regulator, then fuel filter, then carb. What I am wondering is if it would be ok to run just rubber fuel line/hose from the steel line at the firewall to the new mechanical pump, then filter, then carb. I know rubber line has to be used to connect to the pump and filter anyways, but how long can you have it before you worry about any hose collapse or pressure issues? Mechanical pump max pressure is 5.5
