mikeyfrano
finally got my car running after 23 yrs last year and earlier this spring the car died 7 miles from my house. checked it out and it was the fuel pump. When i took it off the engine the arm was still in the motor. so i pulled it out and installed a new fuel pump. it worked until last Sunday when the fuel pump stop pumping again, grabbed an electric one to just get the car home. when inspecting the fuel pump arm it looks like the rod in the engine that drives the pump is just barely touching the pump arm and eventually pushes past it. there appears to be a spot for the rod to rest on the pump arm but the arm isnt long enough. has anyone had this problem or can anyone suggest a quality pump that has a longer arm
