Fuel pump
Andrew
10:12 PM
Smithtown
Just ordered a Mallory 4110 elec fuel pump for my Coronet R/T and would love some suggestions on how and where to mount it. PICTURES would be great, but any input would be appreciated. I removed the Mechanical pump so I wont be running it thru there.
The motor should be putting out about 550 hp- so if anyone thinks the pump is insufficient, please also let me know.
Thanks.
Just be sure you isolate the fuel pump...Meaning use rubber mounts so it will not drive you crazy when the car is running...The closer to the tank is better...Are you also using a fuel cell???
Petty Blue 67 GTX
Then probably your best bet would be inner left fender...Nice car man..
Petty Blue 67 GTX
Electric fuel pumps push, not suck. The fuel pump should be mounted as close to the tank as possible, NOT in the front of the car, in the back near the tank.
