Bob Sawyer
I have the 5,000 box heater in my fully insulated 24' X 24' and it keeps it toasty.
A heater in Florida? Probably get by with a space heater...
LOL I moved to the knoxville, tn area
nice setup!I call those unit heaters,gas or electric!a mini split would be perfect to add ac easy install with just lines through the wall and would likely run cheaper than the unit heater unless it's on nat. gas!you could maintain temp with the split and boost quickly if needed with the unit!I have an old forced air furnace that came with my house over 16 years ago and still works great in the upper left rear corner of the garage. I keep it at 50 all winter long and bump it up to about 62-65 or so when I go out to
Work on something. It's nice to go out even when you just need a screw driver and all the objects aren't ice cold out there also. The older I get the more I want to get some sort of low cost central a/c for out there in the summer. All brick garage with glass block windows for security so I can't do a window unit.
GREAT LOOKING GARAGE.....I have an old forced air furnace that came with my house over 16 years ago and still works great in the upper left rear corner of the garage. I keep it at 50 all winter long and bump it up to about 62-65 or so when I go out to
Mini-Split air conditioner costs though.I have an old forced air furnace that came with my house over 16 years ago and still works great in the upper left rear corner of the garage. I keep it at 50 all winter long and bump it up to about 62-65 or so when I go out to
I see ads for 15K/btu-heatpumps complete with line set everyday on ebay under $700-$1000 that would do that room nicely!Mini-Split air conditioner costs though.
15000 BTU heating or cooling is not very much but the biggest factor to be considered is the square footage or qubic volume of the space to be conditioned (either heated or cooled) and to what desired temperature is to achieved and maintained. In addition, building's materials of construction, number of openings, etc.factor into the systems requirments. True, cost is a consideration but, if, what ever is installed, does not satisfy the owners expectations, then its money waisted. Talk with a person that does HVAC systems rather than just guessing or installing second hand system. Just my opinion of course.I see ads for 15K/btu-heatpumps complete with line set everyday on ebay under $700-$1000 that would do that room nicely!
