440roadrunner
That is what I figured..bad limiter. I got another of a buddy of mine.
Put the limiter in and she moves to empty and thats it...but it does move more that before *g*. I grounded the wire to the tank and the gauge reads full so the gauge must be ok. I am getting power to both sides of the limiter. 12 Volts to one side and 5 to the other..the 5 volts is not constant it pulses which I think that is what it is supposed to do. Could it be the sending unit in the tank be pooched..seems odd the limiter would go same time as the sender.
AL
Could be that the sender shorted, causing high current flow. IF so you are lucky if the gauge movement is not damaged. This is why you need to check this out as a "system"
1 Make sure you have full 12V (14 when running) right to the VR
2 Check with resistors to see if the gauge is accurate
If you put the resistors back at the tank, you now have an "end to end" test --- from the battery, through the ign switch, the cluster, the vr, the gauge, wiring, all the way to the tank. So if the test resistances cause the gauge to read accurately, you know then that the sender is the problem, or at least right in that area
