red 69 runner
I am replaceing my stock intake manifold with a aluminum duel plane type and want to block off the heat crossover.i found a gasket set at summit and it comes with the valley pan gasket and 2 manifold gaskets for each side.do you use 1 gasket then the pan and then another gasket then the manifold?Stock 383 and am going with the Weiand 8008 manifold,stock HP exaust manifolds and the manifold heat control valve is stuck in the wide open position.any info would be appreciated.
