Officer Higgins
200 bucks for brake shoes. Have you used these theory sounds good but man expensive but what ain't anymoreFor the rear shoes etc go here. www.musclecarbrakes.com
Yes. Used them for many years. Smooth, quiet, straight, clean. Great modulation and performance. Will never go to discs. All the brakes I will ever need and I don't poke around in LA Traffic. I slice, dice, and run with th rest of the idiots out there.200 bucks for brake shoes. Have you used these theory sounds good but man expensive but what ain't anymore
I just finished installing a complete "Right Stuff" disc brake conversion kit, M\C and lines, on my 62 Dart Max Wedge car. Quality pieces and everything fit together with ease. Nice stuff!!!Thanks may check that out. Difficult to get these drum brake cars to brake evenly and not pull to one side.![]()
Go to your local junk yard and pull the spindles, rotors, calipers, proportional valve, master cyl and master to prop valve brake lines off any -
Chrysler Cordoba, Dodge Mirada, 5th Avenue, Diplomat, '81-'82 Imperial any M or F body
Some have 10 inch rotors, some the bigger size - the 10 inch set up will fit in your 14 inch wheels. I have the 10 inchers on both my '66's and they work great.
