Going from 904 to 727 66 Coronet column shift
Gscyrkel
8:57 PM
Virginia
I'm sure I'm not the first to ask about this but I have a 66 Coronet I've upgraded to a 440 and 727 from a Slant six and 904. What i need to know is the linkages and everything that runs from the arm on the column in the car down to transmission itself do i need all new linkages or can i simply replace the single linkage nearest the transmission with this one I found online
1964-70 B-BODY SHIFTER LINKAGE ROD/SWIVEL 1-2 - Mopar A833 4-Speed Transmission & Component Specialists
This link is to a more complete kit but im not sure if that's all I would need. If I need to replace everything.
SHIFTER LINKAGE ROD SET 1964-69 B-BODY | Roseville Moparts
Both of your links are for 4 speed manuals, not for 904/727 automatics.
I can't answer your question but i can tell you for sure, those parts you posted are for a833 manual 4 speed transmissions and definitely aren't what you need.
Here are a couple linkage sets on ebay. One says its for 904 and the other says for 727. They look similar to me but there must be a difference. Others here can probably tell you more.
[/URL]
[/URL]
Thank you I've been looking this up for a while and getting nowhere that looks like what I need.
Here's one for sale by a member. Doesn't say if it came off a 904 or 727 though but you could ask.
I would mock it up and see wnat you need, before spending dime one. I went the other way On a car years ago, but I remember it as being straight forward, without buying any parts. You will also have to address throttle and kickdown linkage.
