Thrashingcows
Yup you got it...just put it into gear, hold your foot on the brake pedal, then shift through each gear allowing it to run in that gear for 5-10 seconds. Then in neutral and check you fluid again, top up if needed then go for a drive to get it up to operating temperature. Once back again put in neutral and check fluid level.
