Good "How TO" article with pics on making your own fuel lines from pump to rail
Sorry, but right now looking at running GM nylon fuel system. Uncertain if I will run steel line(with GM quick connect) in between the FAST throttle body and the modified fuel tank.
I do not like AN fittings if I can avoid them. At least on the fuel system.
Thanks for sharing! As far as I'm concerned- information is information and that knowledge can easily overlap. For example I got some great information from Fordmuscle about distributor curves and ignition timing.
