Grant Steering Wheel Quality
Any Installation Pics? Im having a difficult time setting up - Nothing available to cancel the turn signal switch
It just so happens that I have what you need -
In the background, is the back side of my factory steering wheel. You can see there is a stout piece of wire that wraps around the center of the wheel. The part of the wire that turns up is what cancels the turn signal.
In the center of the copper disc, there's a structure that looks like the letter "Q." The leg of the Q is what cancels the turn signal on the Grant steering wheel.
One thing you may want to do is add this bolt and washer on top of the spring that pushes the horn button out. The spring is not tall enough and the horn button will rattle loosely around.
Actually - I have this piece and I had to ream out the inside of the shaft hole because it would not seat far enough on the steering column shaft to make contact to cancel the turn signal switch. THANKS for the pic !
A new Grant steering wheel ready to go on the wife's 67. I added two coats of Teak oil and two coats of satin finishing wax. I think it richened up the look over the bare wood they sent. I haven't used it yet but it seems solid enough
