The part that bugged me as a geologist was, why isn't the shortest day of the year the coldest. Or why isn't June 21st the hottest day. It's the oceans. They are slow to react to change both hot and cold. 6-8 weeks until our coldest days.
Why does seasonal lag happen?
The primary reason for seasonal lag is that Earth is, well... very watery. In fact,
about 71 percent of its surface is covered by the stuff, and it plays a
key role in regulating our climate by evaporating and increasing the temperature of the surrounding air.
However, to reach the point where it’s hot enough to do so requires a significant amount of energy, known as high heat capacity.
One way to better understand it, as climate scientist Karen McKinnon explained to
The Washington Post, is by thinking about what happens when you attempt to heat up some water on your stove – it doesn’t boil as soon as you put the heat on.
“If you think about trying to boil a pot of water, you can turn on the flame under the water, but water has a pretty high heat capacity, and so it takes a good amount of time after you put the heat into the water for the water temperature to actually increase and then come to a boil.”
Now imagine your pot of water is actually the Earth, and you can begin to see why it takes much longer for the weather to become warmer than we might first assume. Similarly, it also takes a good while to cool back down again.
Land
also plays a role in regulating climate and temperature, and thus also contributes to seasonal lag, but to a much lesser degree than water – not just because there’s less land than there is water, but because it has a lower heat capacity too.
