Jamesjames
What exhaust setup did you use? Is there a lot of difference for n the clearance from a 383 which it had originally?. The 440 has manifold on it currently. Anyone know if this will work? Thanks
What exhaust setup did you use? Is there a lot of difference for n the clearance from a 383 which it had originally?. The 440 has manifold on it currently. Anyone know if this will work? Thanks View attachment 1130864
See if this supplier has a system for 1967 Charger with 440. They were an option in 1967, but not available in 1966 Charger. Factory 440 manifolds were different than 383 pieces. I think 1967 RH manifold was different than other years, because of angle of exhaust flange.What exhaust setup did you use? Is there a lot of difference for n the clearance from a 383 which it had originally?. The 440 has manifold on it currently. Anyone know if this will work? Thanks View attachment 1130864
Did you mount from bottom up?Mine fits fine
I used Doug's Headers and they fit like a glove
Power steering & Manual Brakes
The only thing is with the Torker II intake I have
I don't have a lot of clearance room for the air cleaner
View attachment 1130912 View attachment 1130913
