Headers In!
So my TTI headers finally arrived!!! :headbang:
It took extra time because I had O2 sensor bungs installed. I don't have any use for them yet, but might put fuel injection on the car in the future. The $36 is cheap now, so now I am ready if and when I install the FI system.
I have a question below, but first some pictures...
Here are some pictures of how TTI shipped the headers. Very nicely packed!
O2 sensor bung location:
I decided to use the existing studs instead of header bolts so that if I have to loosen a header I won't have antifreeze all over the place. Using studs requires that the second one on each side be shortened for clearance.
I only had one minor clearance issue on the passenger side header. A tab on the bellhousing just barely hit the header...
The tab has no bolt holes and isn't used for anything that I can tell, so I filed that down and that took care of the problem:
The passenger header fit VERY nicely, and has plenty of ground clearance too. Here is the header from above:
And the view from below. Note O2 bung.
The driver side header will be harder, with more stuff to remove. I have to replace my starter too with a mini starter.
So here is my question: The z-bar needs to be removed to install the headers (yes, you must - I tried without removing it!:icon_sad: Below are pictures of the "z-bar" It is what engages the clutch.
What is the easiest way to remove it? It does not seem easy...
As always, help from the experts is much appreciated!
