Progress, Plus Live and Learn
Ahhh, live and learn....
So I made quite a bit of progress today. I got the whole K-member with engine, transmission and suspension out. I didn't have a nice cradle, and didn't have time to make one, so I figured I would use some car dollies I had. I found out the hard way that you cannot support the K member directly under it because it twists upward at the front and tears up the oil filter causing oil to leak out and make a mess. Ask me how I know.... :iamwithstupid:
I NOW believe that the primary support point has to be the rearward mounting holes of the K-member. My K-Member is currently safely supported by jack stands, and no disaster has happened yet, but tomorrow I have to figure out how to make it mobile so I can get it out of the way and get my son's car back in the garage.
For those of you brave enough to look through my jury rigging and fumbling steps forward, proceed to look through the pictures!
To get the K-Member out, first loosen this bolt under the lower control arm. I took the bolt all the way out, but that probably isn't necessary.
The bracket that the bolt screws through looks like this
Take the spring clips out from behind the bars.
There is a special tool to take out K-members, which of course I don't have. So I got some rubber and put it around the bar. Then I clamped vice grips around the rubber and hammered on the side of the vice grip. The bars came out!
I took out the battery tray and brake lines, then the shock, and then removed the upper control arm eccentric bolts. That allowed the arm and all the wheel related elements to flop down disconnected from the car.
I have car dollies that sit under car tires so you can move cars around in he garage. I made "tops" for them so I can use them to move other stuff - kind of like an industrial dolly. I figured these could do the job just fine...
The assembly on its way down (actually the car body was on its way up...)
From the side.
Removed from the car, and a mess!
Other stuff I removed that may help someone as a reference:
The driver splash panel that allows access to the Z-bar (clutch) and the upper control arm eccentric
The passenger splash panel that allows access to the other side eccentric
Shot of the brake lines and Z-bar area.
This is a shot of the transmission interlock that does not allow the key to be removed unless the car is in reverse. I have mostly disassembled it here, but hopefully it provides some general detail...
Front is starting to look pretty bare.
My son's poor car out in the snow since my engine and trans are taking up the floor space...
![IMG_1891.jpg IMG_1891.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/131/131060-bfe0475f1ea186bdec85715781539bb5.jpg)
