Looking good!
Out of curiosity, did you grease the pivot shafts, where they go into the K frame? It doesn't mention it in the service manual, but seemed like it would be greased just based on the metal on metal contact.
I did, but I don't know if it was right to do it. As you said, the FSM does not specify it, and that is because the pivot shaft does not move (or is not supposed to move) in the K-Member. That part is stationary, while the lower control arm rotates around the bushing at the end of the pivot shaft.
The reason I added just a light film of grease was more to ensure that it wouldn't rust in there. With the nut on the end of the pivot shaft as tight as it is - I hope it won't move...
