Sorry for dropping this thread for a bit. The holidays plus losing our one cat Zoe has meant that I have had limited garage time.
When we last left this, my front drum was completed and had .082" clearance, so I am considering that to be done. The rear drum is now also complete.
Here it is after the clutches have been removed and before disassembly of the piston.
Here are the clutches and order they go into the drum.
I disassembled, cleaned and checked all the parts. Really a pretty simple task of removing the bottom wavy snap ring. The piston, like the front drum, has seals that need to be replaced. Once I replaced those, reinserting the piston can be a bit tricky. You need to make sure the downwards facing lip seals appropriately go into the drum. I used a narrow .012" feeler gauge to slide around the seal (lubed, of course!). You have to do this on both the outer and inner seal, slowly working the piston down until it slips in.
I then reassembled the spring and snap ring. Note that the unit had a plastic shim (holding in my hand). I replaced this with a steel shim (in the drum) as this is supposedly much better.
Here is the unit as I was assembling the clutches.
The final clearance of this was .036". This is a bit more than I hoped, but within spec. As
@451Mopar stated, perhaps closer to .025" would have been better. I will leave this as is.
I then used air pressure to check the operation of both drums. Both seemed to work well, and shows that seals are in place.
I then reassembled the drums and rebuilt pump assembly into the transmission. This is the reverse of disassembly, so I didn't take pictures of this. I also installed the tailshaft to be sure I got a good overall endplay number.
My overall endplay is now .044", which is good.
The transmission is now pretty much ready to be installed. Next steps will be to pull the existing tranny from the car, pull out the valve body from that, inspect and reuse that valve body, and then install the whole new transmission into the car. This won't be until mid January, as I will be away from the garage for over a week.
We are finally getting close, but still some work to go!
