Macdon221
Good Day all,
As per the title....69 Charger...Low beams work perfect on both sides (1 bulb on each side)....but when i switch to high beam...both lights come on as they should on the drivers side....but no lights at all on the passenger side (both bulbs off).
Any suggestions?
Thinking not the dimmer switch as it works on one side after the dimmer switch is "switched". So after that?
Thanks for your help
macdon221
Any suggestions?
macdon221
