Best part is if you want more out of the heads just un bolt and take them down to a shop and get another 100 hp. QUOTE]
How bad would these heads have to be to leave 100 HP worth of improvements on the table ???
I'm no head porting guru, but I'm sure that your estimate is waaaaaay optimistic!
I hope this doesn't turn into a long story, but it might.
First, the Stealth can be ported to the same level as the RPM, we've proven it again and again.
As to 100 HP worth of improvements, hmm.
We just had the good fortune to dyno test a customer built 499 wedge with our cleaned up Stealths. These were the best flowing OOTB Stealths I've ever tested.
Lift....................OOTB................Cleaned up
.100.................73/58...................75/69
.200...............143/117...............150/133
.300...............203/156...............211/176
.400...............247/184...............254/217
.500...............270/205...............285/234
.600...............283/221...............295/262
.700...............290/229...............297/280
The 499 was 11.5:1 and equiped with a MP 590, Torker II and 750 cfm 4150.
RPM............TQ/HP
3000.........481/275
3200.........508/310
3400.........546/354
3600.........560/384
3800.........559/404
4000.........552/420
4200.........544/435
4400.........535/448
4600.........543/476
4800.........560/512
5000.........558/531
5200.........545/539
5400.........532/547
5600.........517/552
5800.........495/547
Not exactly a direct comparison but we built a 496 with 10.5:1 solid street roller, Torker II, 950 cfm 4150 and our RPM heads flowing 305 cfm @ .600".
RPM ............TQ/HP
3600..........612/419
3800..........623/451
4000..........625/476
4200..........627/502
4400..........633/531
4600..........634/555
4800..........631/577
5000..........625/595
5200..........613/607
5400..........596/613
5600..........578/617
5800..........563/622 Okay, there is 70 HP
And a fully ported RPM set, flowing 340+ cfm @ .750" on an 11.7:1 451 stroker, Indy single plane, 1140 cfm Dominator, serious solid roller and 91 octane pump gas.
RPM.............TQ/HP
4000..........535/407
4200..........537/427
4400..........542/454
4600..........552/483
4800..........557/509
5000..........570/543
5200..........569/564
5400..........564/580
5600..........573/611
5800..........587/648
6000..........594/679
6200..........599/707
6400..........585/713
6600..........579/727
6800..........575/744
7000..........567/756
7200..........574/787
Nope, you can't get another 100 HP.
It looks more like 235 HP.
