Statement #1
I am also lazy and don't want to change the motor too much. Let's discuss this decisions! With that statement alone you are biting off more than you can chew. If you think plumbing a turbo and tuning it to run well are easy you are sadly mistaken.
Statement #2;
1. Stock bottom end.
2. Around 9:1 with the stock heads.
3. Some sort of small performance cam. The engine doesn't sound stock, but is not real lopey.
4. Edelbrock Performer RPM with a Holley 750.
Engine only upgraded I will make:
1. Trickflow 240 to get some real performance. Please comment on this. An Edelbrock performer or E-Street have much lower flow. Anything else out there that is not out of this world on price? I need to spend big money on the Turbos, described below.
2. Holley Super EFI. 1200 CFM, blow through. I think that my situation needs the ability to plug away on a computer to find the best setup.
3. Holley Hyperspark. Same reason as in #1.
Buying heads,, expensive EFI and costly turbos with a stock bottom end? You are going down an expensive path without much previous experience.
Why not find a tried and true combo that someone has figured out?
Just my 2 cents.
Doug
Statement #2;
Just my 2 cents.
Doug
