daniel_depetro
- 11:22 PM
- Jul 22, 2008
- Sterling Heights, MI 48310
I don't care if it is a 12.999 E.T., I just want it to hit a 12 second pass.
My father doesn't think it can be done with the car (basically) the way it is.
Here is the car information (if you want/need anymore info please ask and I'll answer as best I can).
1968 Dodge Coronet coupe base model (not even a 440). Absolutely no options (except for chome body & belt mouldings, chrome b-pillar moulding and AM radio). Was originally a slant six 3 on the tree car, but now sports a 1968 440 HP2 engine, 4-speed, 8-3/4" rear with 3.55:1 gears and a sure-grip.
The engine has a 770 cfm Holley 'Street Avenger' dual feed 4-bbl. carburetor on top of an aluminum Edelbrock 'Performer RPM' 4-bbl. intake manifold. It does have a Mopar Performance 'Purple Shaft' camshaft, however I have no idea what size it is as it was in there when I bought the car. I could hear it was cammed, but confirmed it when I recently installed the double row roller timing set (installed at 0). It also has headers and has been converted to electronic ignition via a brand new Mopar Performance kit (ECU, distributor, harness, ...). Other stuff includes an Accell 'Super Coil', Mallory 'Super Wires' ignition wire set, Moroso chrome valve covers (same shape as the factory pieces), and Moroso chrome 14-inch drop base air cleaner (with a new Purolator 14x4" standard paper element). I installed a 19x28x3" aluminum radiator so the extra fluid capacity might have gained me a couple pounds even. A Stant 'SuperStat' 180 degree thermostat, an aluminum water pump housing, aluminum water pump, and aluminum thermostat housing help shed some heat and a couple pounds as well.
I also installed the lightweight 1-1/16" bore aluminum master cylinder & adaptor kit, but to be honest it isn't much lighter (1 lbs., maybe 2 lbs. max) than the non-power drum brake cast iron original piece.
It has a mint 1968 Super Bee power buldge hood and 15x7" aluminum mag (slots) wheels wrapped in Kelly 'Explorer' 205/70R-15 (F) & 265/60R-15 (R).
The fuel pump, fuel filter, and alternator were all recently changed as well.
The spark plugs are brand new too.
It has synthetic fluids in the transmission/rear end (with sure-grip additive also) and Redline 'Water Wetter' in the coolant.
The car is "light" (~3,400 lbs.) for being an all steel car with an iron headed 440 and all iron 4-speed (car weighed 3,340 lbs. with the small 7.25" rear & smaller brass radiator, original iron engine parts, and about 1/3 tank of fuel).
I tried a lightweight high torque mini starter but it was rubbing on the starter so I had to stick with the full size unit.
The interior is a basic bench seat taxi cab stuff.
I assume the torsion bars & leaf springs are the stock slant six stuff.
I am going to try to get a pair of slicks for the rear when it comes time...
