Help me identify my 8 3/4
  • Thread starter Deleted member 214
  • Start date
D
Deleted member 214
Guest
741 case, 44" spring perch to perch, 64" flange to flange. 11" brakes. I'm thinking pickup??? I'm taking it to the swap meet at the 'nats and parting it out - 741 case with 3.55 open, 11" brakes complete with backing plates nad hardware but only one drum. If it is a truck housing I think my best bet is to get $40 from a local who buys empty housings and narrows them. I know if the differential was a 489 3.55 sure grip it would bring some good $$$$, but what is a good price for a 741 3.55 open? Thanks!
Easy tell tale if it's a truck rear is the spring pads will be welded on the top instead of the bottom....
3.55 chunk should at least get $100, if not more.
Most of the 3.55 741's are out of the A100 vans. Like Cranky says, check the spring pads.
