superbeedave
What would cause the battery voltage while hot to read 14.65 and at the regulator read 13.65? I did accidently ground out the pos. clamp with key off.
This is a 69 superbee with electronic ign. and 70's charging. It always ran at 13.60 when hot up until about a couple weeks ago. Notice acid coming out of case. When cold the voltage at the battery reads 15.20 and then comes down when hot to 14.65. I have ran jumper grounds and replaced ign. box, ballast res. and regulator and still the same. I have checked the bulkhead and everything is clean and greased. Could the Mopar perf. battery went bad
when I grounded out pos. cable? Thanks,
