Green72Runner
I have been messing around for 2 hours now with no progress, maybe all you guys can help me.
as stated in the title the only way it will run, or even try to fire is if the base timing is way advanced.
Can an ignition box go bad and cause this?
Plugs and wires?
The motor will run for a bit then sputter and die, when it dies it blows back up the primary carb (6 pack set up) and then the primary carb is all wet from fuel.
I have checked the float levels they seem good. When it does run the bowls are dry, but then when it dies it seems to spit up fuel and flood it so i can't start it until i wait a bit.
Any suggestions, things to try?
Could a blown power valve do this?
Plugs and wires?
