Plymouth71
Waterslide Decal Artist
I've got a 1971 Satellite with a 2bbl 318 and 904 transmission. The car seems to have sat for the better part of 2 to 2 1/2 years. There is a flare in the shift between 2-3. The filter has been replaced and fresh fluid added. It seems worse once it has warmed up. Are the bands adjustable? any suggestions on what I can do to avoid a complete rebuild? Is there a linkage or return spring that might not be properly adjusted? Thank you for your input.
