Yes it's the same diagram thanks but the problem is I can't adjust they frame where is the red mark is mine is showing one inch less.
Actually complete front frames are new which i am trying to install.i am only having problem to adjust the k member.Diagonal measurements will tell you if it's square.....or take it to a frame shop. Btw, 1/4" differences is common with way more than that on the body measurements.
Hi like to know the hole Mark on K member which is 54 1/2 is this same hole on top of k member or underneath?
yes
Sorry didn't understand your answer.
The larger diagram in #3 is the same as in post #1.Sorry didn't understand your answer.
Lol yes I understand what you mean.my question is on K member in the top where the engine sits there is hole and underneath of the K member so which hole shoud I take to do measurement of 54 1/2?The larger diagram in #3 is the same as in post #1.
Thanks a lot i was getting confuse here .I was taking measurement from top of the K member where engine sits thats why was not getting right number lol.That diagram is looking at the bottom of the car. So, it would be the hole on the bottom side of the K member. Also, the 54-1/2 inch dimension is the distance between the hole edges, not the hole centerlines. I am looking for a sharper image.
I'll be taking measurements sometime this weekend. Currently, it is raining here in coastal Georgia.
Thanks alot for the help since 3 weeks I was badly stuck with measurements because the AMD frames I got the holes on it for measurements are not in correct place .trosin bar cross member center holes should be 37 1/2 And I am getting 37" so I have to fix that and both frame marking are out and plus 3/8 short.so that means I am big time screwed lol.Pictures of text and diagram from my service manual are below. That 51.73 inch dimension looks like it is between the hole edge and and torsion bar centerline at the aft face of the K member. Stay tuned. Lol. I'll try to take some good images and provide them with the measurements.
View attachment 707171 View attachment 707172 View attachment 707173 View attachment 707174
Is it possible if you get time can you give me the measurement from trosin bar cross member till K member center bolt cuz like to check if there is problem with bolt measurement please.That diagram is looking at the bottom of the car. So, it would be the hole on the bottom side of the K member. Also, the 54-1/2 inch dimension is the distance between the hole edges, not the hole centerlines. I am looking for a sharper image.
