440fish
First of all Merry Christmas to all..
Im going through the "debug" process on the 69 Bee i purchased recently. Bare with me as i don't know specifics on any of the engine internals as it was purchased from a dealer who didn't have any specifications.
When at idle (in drive) ~1050 rpms she really wants to "take off" and i need excessive brake pressure to sit at a light. I cant lower the rpms any more due to the big cam (no idea what the specs are) or it will stall out due to poor vacuum. This lends me to believe that the stall speed on the converter is too low for the engine?
Also, shes very soft coming off the line until the engine gets up in the 3500 rpm range where the cam comes into play. Am i correct to assume a higher stall speed converter will allow it to get up in the rpms some on launch? Sorry, im a 4 spd guy so this is my first 727.
Im not looking to have some sort of a drag car but i feel this thing is dragging an anchor until it gets up in the rpms... I chatted with B&M and they felt a Holeshot 2400 would be good for my needs?
Here's what i DO know about the power-train setup.
440 with Performer RPM, 780 Quickfuel carb, Comp 2" Headers, much bigger cam than stock. mopar electronic ignition. 3:23 gears with 17" / 255 tires.
I had a local speed shop fine tune the carb with an a/f diagnostic tool when i bought the carb so the carburation is pretty spot on. She starts, idles etc very nicely.
Thank You
Thank You
