I have a 69 charger se 383 with a/c fully restored and am haveing troubles with the engine.It has kb pistons,stock 440 closed chamber heads,purple camshaft 284,480,mopar dual plane intake,electonic ignition conversion,edlebock 750 cfm carb.At low idle it runs good engine shakes a bit,if i open carb ever slightly to bump idle it struggles then revs no matter where timing is.Cant increase idle slightly enough to increase so i can use a/c at idle without going from nuetral to drive without slamming gears.when its warmed up the engine will increase on its own sporatically like a vacuum leak.When driving the car it serges down the road like cam loaping even at higher rpm (2000).When i stomp on it it takes right off and when i pull up to a light it serges.It doesnt seem to be predictable.Now here is what i have checked.Vacuum is low and bouncy 6-8,plugged all vacuum lines,set timming everywhere.replaced plugs 3 different brands,new distributor (mopar),new control module,new dual ballast,replaced intake 3 times,once with just pan twice with paper on both sides of pan with high tack,switched manifold with stock and mopar,switched carb to holley,checked firing order several times,new coil,compression is 140 on all holes at 4500 ft of elevation,2 different sets of wires.When i installed the cam i lined up the marks but did not degree.Any thoughts
