From a slow roll your flooring gas right? The the accelerator pump spot is good also? Goofy idea to top all goofy ideas (dangerous?). Windshield washer tank with a little gas rubber hose run to front carb vacuum advance port, need to put a fitting there. Purge the line block or tie in 2nd outlet. Just before you hit the gas start WW pump. Bog or no bog. Would do it on my car, good question.
