Hemi Inline Air Cleaner wont fit Edelbrocks...
Rolling Thunder
9:43 AM
Trenton, IL
I have a 69-71 hemi air cleaner and it wont work on my engine due to running edelbrocks. Does anyone make adapters to run large dia carbs to fit small diameter intake holes?
I see they do the opposite but they cant just be flipped over and used. I need something that goes up some and clears the top of carb then reduces.
Any suggestions? Help
If there was such a thing it would probably raise the breather so high it wouldn't clear the hood
There is a company called Classic Haulage in Canada that makes an aftermarket base for this application. I know they make it fror a 68-back with the round air cleaner, not sure about the 69 up.
This air cleaner looks like it is one of the fiberglass reproductions,
I have mounted several original air cleaners on Edelbrock Performers (used these as replacements for the original Carters AFBs ) using stock dual quad intakes with out any issues, can you post a picture of the bottom of the base plate ?
