Hlicoil sealant
MoparBill
1:12 AM
Western New York
I have threads stripped out on an exhaust manifold stud- 440, 906 heads. I plan on drilling it out and using a helicoil. My question- it's an end bolt so it goes into the water jacket- what sealer do I use? I would normally use red loctite on the helicoil, but I'm not sure with the antifreeze. Any thoughts?
You need to use Locktite red on the heli coil to head. Let that cure completely, then coat the header bolt with permatex high temp red. Works everytime.
